El Dorado engine selection advice
Bunnypig
Just purchased a 62 El Dorado Express....what is the smallest engine that will push it +-20mph?
Any thoughts would be greatly appreciated. Thanks
matt167
Max hp is 100hp. So you want at least a modern 60hp. You wouldn’t want a motor that would only plane out at WOT. That might plane at 15-17 mph but. Your going to want some hp
75% of max is the generally accepted as the minimum. So for you 75hp. But you can probably get away with 60-70hp
Bunnypig
much appreciated..
