I'm getting ready to swap out the old log style manifolds on my '79 260 with a set of center riser manifolds & elbows that I picked up off of an '02 6.2 B-3 set up.
My cooling system on my 260 requires restricted gaskets which only have a small hole, about an 1/8" diameter, in one of the coolant passage areas. The remaining passages are completely blocked.
The restricted gaskets for the center riser manifolds have the small hole in the front & rear coolant passages but the area on either side is completely open.
Is this because of a difference in the design of the newer style elbows & should I use those gaskets that are actually only half restricted or find or make some that are fully restricted like my original ones?
I understand my original cooling system to be what they call "warm" manifolds & very little water exits the exhaust until the engine warms up & the T-stat opens. The majority of the water recirculates back to the engine. My guess would be to allow the engine to warm up faster??? Or to allow it to warm up at all.
These newer style gaskets look like they will allow too much water to exit the system prior to the engine reaching operating temp.
I just want to make sure it's correct the first time it goes together because it's a real pain to pull the elbows off once everything is back together.
Thanks.
Jim
Thanks.
Jim
