Electric Fuel Pump
Chemdawg
Re: Electric Fuel Pump
I am really glad I read this post. After seeing what everyone is talking about, I understand the safety portion of it thoroughly.
I purchased an airtex OS75 oil pressure safety switch, and will connect the electric fuel pump the correct way. Now I have a question pertaining to the wiring of this. I know how to wire it with the pressure switch. However, I see guys talking about using a relay also. How would I wire this with a relay? I'm not really finding the posts that show this.
Chemdawg
Just an update on this post. Hopefully this will help the original poster. I purchased an Airtex OS75 oil pressure switch, and plumbed that in with my oil pressure sending unit. I also used a standard 12 volt relay. Wired it up to a diagram that I found online. Eliminated my dash switch, and put a light there instead. The light stays on when the pump is running, and shuts off if it's not.
When I turn the key on the pump is off. When I go to start it, it runs, and then the oil pressure switch closes and keeps it running.
I am VERY thankful for all of the posts here. This is something I added to my book to keep in mind next time.
Thanks to the OP for the start of this, and thanks to everyones comments.
Highly appreciated.
thumpar
Highly appreciated.
Sounds like a nice (and safe) setup.
