Electric primer leaking Johnson 25
imported_harryt
My electric primer has 1 small nipple (plus a large one), but pic in manual shows 2 small nipples + the large. Mine has hole (and no metal nipple) where 2nd small one should be, and gas shoots out of it. I have not yet found a loose hose to go to a 2nd nipple, or a loose nipple lying around. Can someone explain where the 2nd nipple would connect to? Thank you
JUSTINTIME
Re: Electric primer leaking Johnson 25
go to johnson.com and look at the parts diagram
bgbass.1
those primers are made for a variety of models you just plug that extra hole you dont need it on yours
DHPMARINE
The primer should have one large nipple and two small nipples,with a cap on one of the small ones.Sounds like yours is broken.
You don't have to buy the whole primer.See your dealer and purchase the top cap and the gaskets/diaphrams below it.Don't forget to order the cap if it is missing.
DHP
