JimS123
- Jul 27, 2007
- 8,363
Re: Electric Winch Question
My PowerWinch came with the cable, circuit breaker, etc. Just had to run the wire thru the car to the battery. Piecocake.
People generally DRAMATICALLY underestimate the size of power cable needed to run a winch the way it was meant to. If someone complains that a winch is too slow, first thing to look at is the size and length of the power cable.
Just a quick check on the iboats store, a relatively small 2400# marine winch has a circuit breaker at 60 amps. Lets say it draws 50 amps max during pulling. For a 25ft run to the battery (remember, need to ground it also to the truck frame, that distance counts), you are between 4 gauge and 2 gauge wire! (8 gauge would drop 2 volts in that run, 4 gauge is .7, and 2 gauge is .5)
I've seen people plug a winch into an adapter for the lighting harness! At best, that is going to be 12 gauge. If you don't pop the fuse, the voltage drop is going to be over 5 volts.
