dolluper
- Jul 19, 2004
- 3,910
Hi guys you won't believe this one ..an old 92 olds came in and had a lean condition ..o2 sensor solved that problem then at the e-test the nox gases were way high .....=high pressure i combust chamber ..carbon build up ,bad cat ,cooling system bad,egr system if it has one ....none on this vehicle ..3 way cat instead,or lean cond....advance to far....replace the cat and the numbers increase from the old cat go figure what do you think caused this ....you will be surprized but give it a shot ...don'r be shy lol
