engine alarm. Where is it normally?
madgadget
Hi all, is the engine alarm usually in the controls or behind the dash. I'm soon going to be fitting out a 'new' hull and I need to know where I should find such a thing. Also, I may need to purchase one what kind of thing should I be looking for?
Cheers :)
Barnacle_Bill
Re: engine alarm. Where is it normally?
It can be either place. If you can, turn the key on, then ground the wire going to the temp sensor in the head. That will make it sound.
Dukedog
If its gonna be a NEW installation with a new harness, usually tha buzzer will be attached to tha harness at tha dash end if its a Merc/Mariner. Should be a little round thingy with two wires (purple, tan), wrapped in a net lookin' sack. Unless its some of tha newer Opti stuff.
If its already in tha boat do like "bhile" says ta find it...............
madgadget
No there def isn't one on there. Ill locate the wires. Do you know what kind of sounder I need to get?
madgadget
I need to purchase the alarm/sounder. Where and what am I looking for?
Dukedog
Merc part number is
816492A1
Don't know if there is and aftermarket or not. Might be superceded to a different number but they should know about it if it has been.......................
