Engine alignment
meesh
1980 Mercruiser 350/260. Alignment bars goes in easily at top 90/180/270 degrees. Pushes in with one finger and turns easily with two fingers. Everything back there is new. My only concern is that at 270 it has a little more resistance than the other three sides, but still goes in with one finger and turns with two. Am I being too fussy considering that the mounts will allow some minor movemnet? Just want to be sure so my new coupler will last.
Thanks!
ziggy
Re: Engine alignment
that's exactly the way mine was fall of 07.
ran it all year w/o issue. est. around a hundred hours
this fall i only checked it where it fell off at... alignment bar went in nice and smooth...
i don't turn my alignment bar. i put spline grease on it and withdraw it and look at the spline pattern. looking for consistence in thickness of the grease all around..
Ayuh,..... It sounds like it to Me.....
Grease it like Ziggy says,+ read the Tracks for fine tuning....
meesh
Thanks guys! Cant help it, I'm a perfectionist.
Steven K
Are there any signs of an engine needing alignment? It has been several years since it has been done on my boat. This year it developed a noise that I thought might be the gimbal bearing, but now I am curious.
ziggy
steve, sounds like you need to start yourself your own thread with the problems your having with your particular kind of drive... you've come to a great place to get help and info at.... read this and post away man.
http://forums.iboats.com/showthread.php?t=220416
that's good. from your short discription, it sounds like you should be.... whatever drive you have...
