Re: Engine Cooling
If you went to the trouble of pulling the lower unit off you should have replaced the impeller, they aren't expensive and sometimes looks can be deceiving. The thermostat is located at the rear of the engine on the top of the cylinder head underneath a cap that is held on by 4 bolts. Water flows up the water tube from the pump, fills the cylinder channels and the pee stream. When the thermostat opens full flow is established through the head and out the exhaust relief holes in the back of the engine beneath the powerhead on the trunk of the outboard. If the thermostat gets stuck closed the engine will overheat. There are a number of other issues that contribute to overheating engines. Rule out the basics first. Be aware that the pee stream is only an indicator and the cooling system can work fine with it completely plugged up. However, if the cooling system is not working correctly a weak or non-existent pee stream may be an early indicator of trouble. Make sure the pee stream hole isn't plugged with crud. Stick the red tube off a can of WD40 up inside and make sure its clear. Remove and test the thermostat in a pot of water and make sure it opens at 50 degrees Celsius (122 degrees F).
