veritas honus
- Jun 13, 2010
- 1,876
Re: engine fumes in cuddy
It's rubber; and for nineteen years old, it's in amazing condition. My boat has been beautifully maintained by the original owner, and then by my Father-in-Law, who gave her to me after six years and only about 10hrs on her. She'll continue to be beautifully maintained by me... But anyway, thank you again. This issue will be resolved before the spring. I'm going to take her out for a three day weekend in two weeks. After that, full winterization/maintainance.
Safe and happy boating always!!!
A lot depends on the type rub rail you have. If it's like mine that is solid rubber, then yes you can reuse it if you don't stretch it too much. If it is a hard plastic or metal one and you damage it, then no.
In either case use care, and think about what you are going to do, have help to support it, then do it.
Some rub rails have an insert that hides the screws. Those can be reused or new screws can be positioned to new holes, but if you do that the old holes must be sealed.
All the rails I have seen are held in place with SS screws but that doesn't mean there aren't some out there that are glued in place as well.
Hull to deck joints on a lot of boats are only held together with screws, some are joined with an adhesive, while the best are a combination of the 2 with a backer for the screws. There is a lot of movement between the 2 sections and they can work loose over time, allowing the leak.
Enjoy.
