engine hard to start when hot
I pulled this. Not sure how to test this. The sensor reads 10.7 ohms. But did not change reading when I ran a hair drier over it. Only went down to 9.8 Ohms after ten minutes in the freezer.
you connect a pwm power source to it, and depending on what the voltage is, the IAC opens to that point (or closes to that point) its a small stepper motor that opens and closes a throttle plate bypass
Jack2048
Well, that seems obvious now, probably tired when I looked at it last night.
No PWM Supply here, but, the IAC opens when given +12v.
The Air Charge Temperature Sensor responds appropriately.
I restarted the engine, hose from the fuel pressure regulator to the plenum has good vacuum and does not appear to have any leaks. Nothing coming out of the regulator.
alldodge
All the sensors controlled by the ECM use 5V, applying 12V can damage them.
Nothing should come out of it, vacuum controls the pressure increase. Even though the ETC responded appropriately do wonder if the engine thinks is cold and supplies more fuel. Need a scanner to see what the ECM is seeing
Jack2048
Ok, good to know!
This was not a sensor but the stepper motor. To determine polarity I was looking at the signal on the connector which read 14.5v.
Right, agreed. But I was reading somewhere in one of the manuals to which I was pointed, that the regulator should be checked in this manner.
Water temp sensor ok.
alldodge
This is the wiring for the IAC on a Merc motor and so far as I understand, same parts are used by VP
Jack2048
I unbolted the IAC and covered the opening. Running the engine, I did not see any movement on the valve. I don't know if that helps.
alldodge
That is weird, the motor should have died if all the air was closed off from the IAC port
Jack2048
Yes, at the same time the computer had the valve closed while running. If attached, it would be the same as my tape covering the holes. Wouldn't it?
After cleaning the IAC, there was dirt in the metal filter, the uneven idle seems to have gotten better. I want to re-check this when the engine is cold, in case it was just a byproduct of the engine being warm from when I ran it earlier in the day.
Next to check is the PCV.
Jammer864
There are 2 temp sensors on that engine. One for the gauge on the dash and the other for the computer to tell it how hot the engine is. Using the factory manual for temps vs volts (page 3-15), check the one driving the computer, Also I couldnt tell but have you had the injectors flow tested? Possibly one or more are leaking?
Jammer864
from a former Ford mechanic that knows the Ford FI fuel system......"when voltage is low, the computer interprets that as being cold, so more gas is added to help start. Make sure battery connections are clean and tight, and check cranking voltage at the starter. The computer may think its cold out when in reality its only a poor connection." Just a thought.......
