deejaycee_2000
- Mar 28, 2006
- 3,447
To get your boat to run higher out on the water, should you lift the motor up on the transom or down ... basically if you run the motor deeper on the transom would the boat run deep, and when you run it high on the transom will the boat run higher on top of the water? ..... I know the answer but for some reason I have lost all common knowledge today ......
