I have a Reinell with fly-bridge and twin 302 OMC's. I got the boat with these conditions present. Left engine goes to crank immediately when you turn battery switch on. No keys in ignition switches. Right motor doesn't ever get 12 volts to starter solenoid when in crank. So we had no keys anyways so all 4 ignition switches I replaced. Can someone describe how these were or should be wired. I found on the fly-bridge switches that there are wires present for battery, ignition, and start and replaced them exactly as they were. They look to be as I would expect. Downstairs there is only multiple wires on the "on" tab and one wire on the "start" tab. Nothing is present on the "battery" tab downstairs. So My thoughts were you could only restart them from downstairs and the fly-bridge switches must be in the on position. Is this true? Also the condition of immediate crank on left motor and no crank on right motor stayed the same when I R&R the switches. Any thoughts or does someone have a diagram? Its a 1977 Reinell 24 or 26 foot full cabin cruiser.
Thanks Mitch
Thanks Mitch
