ziggy
- Jun 30, 2004
- 7,473
Re: Engine Knock Merc 165HP - Help!!
i think ya'll need to remove the dist. prior to the ft. push rod cover comeing off.....
i think ya've already kinda checked the lifters myself.
it does sound like yer knock is in the bottom end or the engine. i'm not the pro. but if the ujoint were bad in the drive. perhaps it's knocking. guess ya could try turning the drive hard over when it's makeing it's noise to help eliminate that idea......
use yer hearin hose to help locate the knock anywhere. it's a good diagnostic too for what it is. a piece of hose........
ya could check again with a hearing hose to ea. individual rocker thus locateing a noisey lifter. another method notein in my sevice manual is to place a finger on the face of the valve spring retainer. if a lifter in not proper, a distinct shock will be felt when the vavle returns to its seat.....the way i'm gettin it from reading the service manual is that ya check lifters these ways. aslo states that if ya find one bad one, ya should rebuild all........i don't think ya bench test them.......I've had it running with the valve covers off and eliminated any noise from the rockers.
