matt167
- Sep 27, 2012
- 4,379
Re: Engine Oil, here we go again
What is the API Spec on the Mercury Quicksilver oil? I seem to remember that it had quite a bit of Zinc in it and auto enthusiasts were picking it up as it was cheaper than the racing and diesel oils that are common to have zinc in them.. The EPA relegated the reduction of Zinc in automotive motor oils as it is a pollutant but necessary for the longevity of flat tappet camshafts, so even trucks and cars from the mid 90's that still had flat tappet cams will actually get the wrong oil if you just go and buy whatever from the store shelf. It will run with about anything but the cam will wear overtime... This is why I'm curious as to the API spec of the QS oil as I don't think it is regulated by the EPA in the same way and is likely 'good old' oil with lots of zinc
