Engine Re-Build - Wire and clearance
drew_caplan
So, as as I near the completion of my 4.3 rebuild, I have two questions.
1. Anyone know where this wire goes?
2. I installed an aftermarket intake, and I am not sure if the position of the thermostat housing is slightly different of if the clearance is always this tight around the fuel pump bracket and the alternator.
Ayuh,.... Generally speakin', yes,......
There's usually enough room, but rarely to much room,......
