76SeaRay
- Aug 24, 2017
- 1,071
Engine is a scratch built but pretty much a stock 1996 Chev 5.7L Vortec with the Xtreme Marine roller cam and roller tip rockers (yes, it is marinized). I currently have a marine Rochester QJet carb.
So, getting ready to light this engine off on a run stand and need to get the appropriate sensors installed. The list so far is as follows:
Oil Pressure Sender - Mercruiser P/N 815425T
Water Temp Sender - Mercruiser P/N 806490T
Thermostat - ???????????
The T-Stats that I have found say closed cooling but I will be going with raw water cooling. Temps seem to be either 140 or 160. Since this is a vortec, I believe it should be run a little hotter so thinking of going with the 160.
Does anyone know the part number for the correct T-Stat for raw water cooling and have any thoughts on the 140 versus 160 issue??? Thanks....
