Limited-Time
- Mar 30, 2005
- 5,820
Re: Engine shifts into gear, hard to shift out of gear
In the diagram Don posted the purple wire feeds the dist the required voltage through the Shift Cutout Switch (SCS). The SCS id normally closed. When the SCS activates it breaks the supply voltage causing the engine to "stumble" allowing the dog clutches to disengage. There is no tie to ground.
