Hi all,
First , please forgive me for my english level, i'm a frenchy !
I expose my problem.
I recently overhaull my 454 OMC/Volvo-P Gen 5 1992, engine had 200 hours.
I decided to install a fresh water kit ( Econo cool), after flushed all the dirt between the cilynder walls.
Everything is OK, but the engine stay cold ( below 60?F )
I thought it was a thermostat problem, stuck open.
Before checking thermostat, i checked gauge by verifying with another gauge
( directly connected to the temp sender, negative and positive pole on the battery)
The problem remains, impossible to reach more than 120? ... except when ignition if OFF !
When i turn off the engine, temp gauge increase directly and seems indicate correct temp ( 160? )
If i turn the key on the ON position, it drops immediatly to 120?
Coolant is very hot, so my opinion is that the temp gauge is wrong
My questions are :
1/ I changed the temp sender by one I bought on summitracing for around $14 ( automotive one ), can the problem come from
this non-marine thermostat ?
2/ why do this temp gauge seems to indicate the right temp ONLY when ignition key is OFF ?
3/ Does anybody have install this kind of fresh cooling kit and encounter this problem ?
PS : i removed the bit of teflon I had put on the temp sender threads, problem remains , thermostat comes from the
econo-cool FWK, i'm pretty sure engine is HOT , exchanger hoses are under pressure
Thanks by advance for your responses, and all the knowledge we can find on this forum
Au revoir et merci !
My questions are :
