engine/trans id help
yonu
Re: engine/trans id help
Well just picked up the new stern drive other than needing new paint it looks good they said it was just rebuilt but for good measure I am gonna change the water pump and gear oil there was still even grease on the drive shaft
I will order that pivot ring when I order humble bearings.
yonu
first humble = Gimble I hate autocirrect
ok I thought someone might be interested in a upper unit pic or two when I got home I decided to pull the top off the old drive upper unit and here is what I foundIMG_20131026_172812.jpgIMG_20131026_172815.jpgIMG_20131026_172820.jpgIMG_20131026_172824.jpg
So all I can say is I am glad I found a new drive
alldodge
Pretty much a mess in their.
Note: I wouldn't order a gimbal ring until you know it's bad. It may need the top pin but having a look and the seal can always be a good thing but requires taking the pin out. Removing the pin is best done when the engine is out, it can be done from the out side but more difficult.
yonu
ok got ya I will wait then thanks
Yonu
yonu
Hey question I am putting together my basic part / tool list and have a dumb question for the purpose of realigning the gimbal bearing can I use an extra driveshaft or should I order an alignment tool?.
Thanks
Yonu
84EdH
if your going to work on your boat, get the tool.
yonu
ok thanks figured I would ask
guess that goes on the list
