I started my boat for the first time to flush the antifreeze and see how it was running. Put new plugs and fuel filter on. Fired right up and I let it run for a while to juice up the battery. After a few minutes it stalled and it has been 2 weeks now still no luck starting it. Does not sputter, nothing.
1999 mercruiser 4.3l mcm thunderbolt ignition.
sn 0L209920
I ran thru what I could of the troubleshooting guide with exception of spark gap test and are going to do a check on the tach wires as posted in other topics. Here is what I found.
Fuel is entering carb
Spark test with spark plug off. Looked ok. .I'm not sure if it was weak.
Checked voltage at coil. 12v
Checked voltage from red/wht of ICM ~10v seemed a little weak.
Cleaned corrosion from all distributor components - not yet replaced. and checked ignition sensor switch for cracks
Oil is clean and new.
I know there have been some similar issues posted but this engine was purring before it just stalled. Anything else I can look for?
Ken
sn 0L209920
Ken
