Engine wouldn't fire without throttle after overnight
KD4UPL
The only numbers I have are in posts #4 and #11. I didn't get any actual numbers from my mechanic (but I can ask if it helps). It does seem the regulator is either bad or at least periodically gives low pressure which would still be bad.
Is there a downside to just running it this way with a little throttle at start up once in a while. The overall power and performance of th engine are fine otherwise.
Any experience on if pulling the engine is really necessary to make this repair?
