phoenixgold2100
- Feb 3, 2013
- 154
Is there anyway to tell what year a johnson 150 is without the serial number plate? thanks
| [h=1][/h] |
Thats the same rectifier. I am thinking the same thing the power head has been changed along with the harness. i am having trouble hooking up the tach and the trim gauges. Do I just run a wire from the tach "s" to the gray rectifier wire? find the trim sender and wire it to the gauge? Also for hooking up an engine temp gauge will i just run it to the tan wires coming from the cylinder heads? the wires just don't seem to be in the harness. not sure if that pic helps at all. it's a v6 looper 60 degree 150. the engine was painted and new stickers on it. thanks again
