enginge swap 470 to 4.3?
alex3012red
finally getting rid of the 3.7, repowering with a mercruiser 4.3 complete with outdrive, i currently have the 3.7's wich has a diff ratio, is there any other things i need to replace. both engines are 88's, with alpha gen 1 outdrives.
anybody done this swap? i do have plenty of room for the 4.3! and will get it complete with outdrive,gimbal housing ready to drop in from a current running and very good cond boat!(owner replaced with 5.7mpi).
Re: enginge swap 470 to 4.3?
Ayuh,... Swapping Complete drivelines, Should be a plug,+ Play swap...
alex3012red
iam picking up the motor on tuesday(it was still on boat when purshased), i don't have an idea if the ratio on both outdrive are the same, mine was rebuilt last season! maybe i should keep it for spare. i'll post some pics and let you know how it went. thanks
actaeon9
Please do...I'm considering a similar swap and would be interested in seeing the before and afters!
Good Luck!
alex3012red
sure we already have the 470 out, waiting for the 4.3 on tuesday! Ill take pics on tuesday!
Big Boat Bay Buster
The 470 uses a 6 cylinder drive ratio---Should be the same as the V6.
indy440
did the 470 use the side engine mounts like the v6? If not, plan on adding them.
