Re: Enricher Question?
Hey Planks! I just tested all kinds of **** on my 90 hp merc. and the enrichner was one of them... Now mine might be differnt then yours... so take this to what ever you can use... Turn switch to on position, push in on key or activate enrichner, if the valve opens you should hear it click, if not don't panic! because there is another test, if no click obtain a volt meter, set scale to 12VDC scale, place black lead to powerhead ground, and red lead to the enrichner wire running to the terminal block on the powerhead.(my wire was yellow & black) if the meter regesters 12V, and you don't hear it click, then it's probally your enrichner. GOOD LUCK! Bro! and hope this could help!
