erratic timing
Jcris
Hello,
I've got a 1996 4.3 LX Gen+ Mercruiser. It's a Thunderbolt 5 ignition with a 2 barrel carb. I recently replaced the plugs, cap , rotor. Also replaced fuel/water separator and inline fuel filter. I set timing to 10 degrees BTDC at 650 rpm's while grounding the timing lead. After the tune up work I also installed a momentary switch on the fuel pump. Did that to allow manual priming of fuel bowl. After the fuel system work and momentary switch install I used the switch to prime the bowl and check for fuel leaks. No leaks so I started the engine. I did use you a good quality timing light but found the timing to be rather erratic at idle. By that I mean the timing mark seemed to float between about 8 -12 degrees. Could this be an amplifier issue? If so, how can I check it? I've checked the forums and wanted to post here.
Scott06
Assuming you are seeing this when it is NOT locked in base mode, I think that is the way the V is supposed to work. Module adds advance and looks for an rpm change repeatedly. If rpms go up it adds more advance.
http://www.boatfix.com/merc/servmanl/16/16b4r2.pdf
Is a link to a manual outlining how the V advance works. Assuming it runs ok, If in base your timing is steady check that your advance gets 28-30 degrees total by 3500 rpm or so it's doing its job.
Jcris
Thanks Scott,
I should be able to check it again tomorrow
Jcris
