Eska carb.question
dude11
This Eska 7.5 is air-cooled,with an impeller.If that's not enough,it's a 2 stroke Tecumseh.Well the question is,has anyone ever tried a 4 stroke carb.on one?? The fact.carb.has a duck-bil fuel pump & bowl/float system.If the gasket were re-done to cover vaccum hole,,one would think it might work or is it completely out of question.Any thoughts??
Grub54891
Re: Eska carb.question
If ya need the duck bill to pump fuel,how ya going to pump fuel without it?
brim_buster
disregard what I was thinking, thought you wanted to run straight gas in it:facepalm:
dude11
how would it lubricate itself internally.
So the hole I was talking about(in the power head) to block is how the bottom end gets lube? I kinda thought the reed deal did that as well as chamber. I was spit-balling anyway,,Just looking for a way to save a motor.I been fooling with this carb.cleaning,etc.Still won't advance as it should.I ain't give up yet.
MahtyMaht
Throttle on the outboard is actuated by a cam on the stator moving a vertical pin staked onto the throttle linkage. You need to yank the throttle shutter shaft out of an outboard carb to put into the lawn mower, but lawn mowers are gravity fed, so no pump.
dude11
Your correct,if I do this I can switch the shaft with mine,shouldn't be a problem.As stated,this motor has the tank above the carb.so I felt like that may be enough,just not sure.I was hoping someone had tried this before and could verify if it would work.Thax for your input.
