eska with reverse?
kenfyoozed
i have a 5hp eska, did it come with reverse? i have it as a kicker on my v17 sailboat. it sucks not having a reverse to get out of the dock. so any comments?<br /><br />neil
D
DJ
Guest
Re: eska with reverse?
kenfyoozed,<br /><br />Can you spin it all the way around? If you can, that's your reverse.
kenfyoozed
it does spin around, but what about a neutral gear? or do it have to start it in drive?<br /><br />neil
D
DJ
Guest
kenfyoozed,<br /><br />If you do not see a lever of some sort, it's a start in drive model.
steelespike
If you start it at a low speed you will usually have time to rotate it to reverse with no trouble.<br /> We used to do it with the little Johnson TD20.
