Sea Rider
- Sep 20, 2008
- 12,345
Re: Ethanol Related Issues
Practical method : If you disconnect hose from tank and with a suitable tool, pencil, whatever, you prees the small ball or pin inside tank connector hose to remain open and let air in, will have pump sucking all fuel leftovers on the line, next pump leftovers, when engine is about to die of fuel starvation, pull/close choke and throttle arm near wot until nearly dies, repeat procedure untill engine dies completey and will not start again, that way will have last drop of fuel burned by engine as stated by Tohatsu Guru.
Have not removed bowl screw after that procedure, will check to take the nail out to check if wether complete empty or with small gas remains. Anyway, I always boat frequently all year long, no issues whatsoever with minimum gas leftovers inside carb bowl. Works near perfection on 2 strokes single carbed engines, don't know about multicarbs.
Happy Boating
Happy Boating
