Ethanol treatment
Jakem
Looking for advice on a treatment product to reduce ethanol...our gas price for anything that doesn't say may contain 10 percent is outrageous.
dubs283
No additive will erase ethanol in your fuel. If the fuel contains ethanol, that's it, no changing that. Most marine engines are okay with up to 10% ethanol gasoline. It's during extended non use that ethanol causes issues, e.g. water contamination, phase separation, etc...
As long as you're using a decent stabilizer with ethanol fuels you should be fine. Mercury makes a three part system that has yet to create issues for me, ymmv
Jakem
Kinda figured that would be the scenario but worth the ask
ROY WILLIAMS
STA-BIL 360 Marine Ethanol Fuel Treatment​
I did it over 20 years .. then I suck it out in the fall ..then put in my truck ...
I also put marvel mystery oil that the corrosion is no issue ..
MMO I put my vehicles old vehicles in The gas tank 2 OZ .. 20-25 gals tank..
Scott06
You will have no issues with ethanol as long as your fuel lines fuel pump and carb internal parts are modern ( aka recent carb kit , new hoses) and you burn through the gas reasonably quickly. At end of season treat it with stabil and you will be fine.
Jakem
Its all new and modern...I burn through gas as I use boat alot
Jakem
It is...finally....alotttt of hours spent scratching my head and robbing my bank lol.
Scott06
Go compare what $ you have in to more late model used or new boats and you will feel better... given the age of the boat and the semi obsolescence of Ford in the marine environment you had some headwinds.
Jakem
It's all good...she Flys now and purrs like a new kitten
