Evinrude 115Hp V4 Project Rebuild / Repowering a Fourwinns Fling Turbo jet boat
Jon NL
So back from a week at the cabin, I have the block, crank, rods and pistons in the truck awaiting for my next move. I have found a local guy selling parts for this motor that i plan to go look at and probably pick up for the right price
Jon NL
Update .....
If anyone is following
Picked up the parts tonight $25
Crank is shot :(
I should get
two rods
crank rings
Starting motor
Lots of other extra parts
I am going to check into a new crank
Put a wanted ad on the local classifieds had a few responses
Jon NL
Just called the dealer and the crank is discontinued and zero left in stock they were selling for $230 like @racerone said
Anyone know of one ?
Jon NL
So group I had a look at the block, muffler, adapter plate for signs of freezing and did not see any obvious damage. Are there any common places or things I can to to make sure there is no damage before I start to shovel $ at buying parts ?
Jon NL
Pulled the bearing off the end
Jon NL
I called my local Evinrude dealer in St John's newfoundland looking for a crank. I told the guy it was a 1995 he said crank should be part # 434 769 and they are discontinued and out of stock in Canada :( and they were $230 .....
https://www.evinrudeparts.ca is out of stock also the guy there was very help full and told me that 92-97 (88, 90,100, 112,115)HP all take the same crank ...........
Hummmm what to do ?
Jon NL
241B8E46-E88E-4DFC-9E51-4CFD4995BE70.jpegFAA17E9A-A1AF-453D-8FB0-32151805FC66.jpeg4DF39F99-C320-4273-8682-79C87B6F091A.jpeg
Started to clean up the crank to see how good it would turn out, looks good but it still has Pitts in it that your finger nail catches on
I am thing this method works on cars as it has a bushing style type bearing ? And this has roller bearings that run on this surface ?
Jon NL
My wife puts up with a lot ..... now trying to remember how to measure with the micrometer ffs
At a job interview I was asked if I knew how to use the tools on a table.----After taking just 1 measurement with a 1-2 " micrometer , I asked interviewer if he wanted more done.-----He said --" good enough " young man.-----When you come from a shop where tolerances of + /- 0.00002 can be held it was all easy for me.
The top cylinder is always #1.-----There is just no way that these journals can measure to be over 1.3762"
Jon NL
Measured it twice pen is the 1st time. I am not putting much faith in my princess auto measuring tools
