mfgniagara
 - Aug 17, 2010
 - 92
Let me start by saying I own a 1965 MFG Edinboro and a buddy has an MFG Westfield. I run a 1990 110 HP Evinrude V4, he runs a 1974 65hp 3 cylinder.
We run the same water and the same route, sometimes we take my boat, sometimes his. He had some issues with his motor and recently just did a complete top to bottom overhaul, (Done by a pro outboard rebuilding service).
Both our motors are in tip top shape as are the boats.
My question is, did those three cylinder engines burn a lot of gas compared to a V4? My V4 will make one particular 11 mile run down the river and back on less than 6 gallons, his 65hp three cylinder burns nearly double. Both motors are propped to run within a few hundred RPM of their max rpm, and I carry more weight and have a slightly larger boat.
Were those three cylinder engines known to be hard on gas?
When I noticed how hard it was on gas, he said this motor, and two prior to it all got about the same mileage, and that this one was a bit easier on gas than the last two. He has three tanks onboard and needs to fill all three, he's got a fixed 20 gallon under the bow, and two portable six gallon tanks. I made the mistake of only running his with a single 6 gallon on a shorter run the other day, and nearly ran out of gas, while my boat would have had fuel to spare on the same run. His boat runs about 28 MPH, mine at about 32 at max RPM. Mine has a bimini top that sits pretty high, his has the factory top that stretches from the windshield frame back.
This concerns me since I am considering powering another boat I have with a 70hp three cylinder Johnson, vs a 55hp twin cylinder Johnson. I was leaning towards the 70HP but if they are that hard on fuel, I'd have to carry too much fuel to make the swap worth while. I'd be adding more weight to feed the larger motor.
Any ideas as to the mileage of a Crossflow V4 vs the inline three looper?
