bigchunkytaco
- Feb 6, 2011
- 54
hi guys i have an evinrude 50hp, got it running well for an old one, i replaced a few of the lines cleaned carbs etc as they were a bit split and leaky, however recently when i throttle higher it kind of cuts in and out with power, the same way it did when it was starving of petrol before i replaced the lines, thats what it feels liek to me,
i also thought maybe the filter, it seems fine except for the outer diaphram looking a bit worse for wear? it almost looks like its a bit loose on the shaft, like the middle of the diaphram has worn away could this be the issue?
any other ideas?
she still starts first turn and runs fine at low speed just when i increase throttle past 60% or so....
any other ideas?
