miker-gr
- Aug 5, 2008
- 76
I want to remove the FastTrak trim/tilt unit from my outboard (a 98 V4 ocean pro model) because i need to paint it.
I have a SELOC manual and it start the description of procedure on how to disengage the wiring.
It says to remove the harness clamp then disengage the system 2 pin connector, disengage the 2 bullet connectors for the tilt limit switch, disconnect the remaining power wiring connectors, remove the rubber grommet ... and some more infos.
My question is where are all this connectors?
Are they located inside the lower cover of the outboard or they are on the side of the FastTrak unit???
