I did compression test using the starter, I saw it was around 65 psi both cylinders. didn't check the gap, on plugs yet. Previous owners had a 1/4 fuel line running from the port, to the fuel pump. it looks like the same from the fuel pump to the carb. took out that line and put 5/16 from port to fuel pump, with an inline filter. I have always loved inline filters, for its clear (absence or presence of fuel) Now I'm running after market, fuel lines that don't match with port or old metal tank. Because of a metal post on both sides. Gotta find away around that, looks like grinding? On the tank, there seems to be a relieve valve and another little metal rod next to it. What are they? Any help is good help....
