Evinrude electric shift cable change
kptrapper
This may sound simple, but I need to change throttle cable from the control box for mid 70's 115HP evinrude, Electric Shift. Removed cover and took handle off, but cant figure out how to remove cable end. Thanks for any response, I appreciate it. Gary
OBJ
Re: Evinrude electric shift cable change
Hey Gary....<br /><br />Look at where the casing guide and control handle meet. You should see an allen head set screw on either side. Loosen both sides up a few turns to release the core cable. Once the core cable is pulled out, push out the anchor pin or dowel and the casing guide will fall out. To install the new cable, reverse the process.
