Re: evinrude ski twin timing question
Miss, idle pop, lean sneeze, whatever you want to call it. It is caused by too lean on the fuel/air mixture. Either too much air or too little fuel, results are the same. In your case, it would seem that the carburetor is not running out of gas, expecially if you give the squeeze bulb a mash. So that pretty much says it is not the fuel pump that you are considering.
You have pretty much covered most of the possible causes. But to list some of the most common:
1. SLOW SPEED NEEDLE OUT OF ADJUSTMENT
2. Obstruction in the slow speed circuit of the carburetor. Only way to find it is to take it apart and look.
3. An air leak into the crankcase---can be anywhere. Note: If it is visible, you may see smoke puff out when it sneezes
4. Carburetor throttle butterfly opening too soon (sync). See my previous notes on when it is supposed to start opening.
5. Carburetor throttle butterfly not closing. Something holding it open??? It should be completely closed at slow idle throttle position.
6. Scored piston skirts, or cylinder walls. Broken or stuck rings.
7. Somebody has goofed up something that I have no way of guessing. Crystal ball is broke. Sorry.
Just a thought---concerning #2, you mentioned the needle packings. If somebody had that needle out and pieces of packing got up inside, they may be obstructing the idle discharge ports, found under the welsch plug.
