Spivy30
- Jul 19, 2008
- 299
Last night I was out on the lake on my boat a 1987 Sea Ray with a 3.0 mercruiser i/o which was running great until it kind of bogged and shut down. Of course I was in the middle of lake and it would not restart, finally after 15mins it restarted and was running fine for about 10 mins and then the rubber exhaust coupler on the manifold blew out and it would not run anymore. What happened? I feel like I over heated the motor or something but I was never over 200 degrees and I had good oil pressure. I checked the oil and it looks clean and perfectly normal. I pulled off the cooling hose that goes to the manifold while the engine was running and there was a slow stream of water coming out. Do I need a new water pump?
