Exhaust Elbow Fit Problem
76SeaRay
What happened here (pics below)? I assume I have the wrong elbow to Y pipe. Anybody know what part I need to fix this issue?
tmagyar
A little hard to tell if this is maybe all it is, but...maybe you are just missing the rubber collar, like mine has to act as the go-between?
Just coincidentally I took this photo today of my almost-ready-to-install 4.3MPI rebuild.
Tom
76SeaRay
Thanks, I have the rubber couplers but the one that connects to the Y pipe isn't long enough and the other one doesn't seem to fit the manifold elbow. Notice how the elbow is larger on one end. I assume that is supposed to go towards the manifold elbow but not really sure.
achris
More fish than mountain goat
There are 2 different dry-joint elbows, and they use different intermediate elbows.
Can you supply the casting numbers on the exhaust elbows and the intermediate elbows?
Chris.......
achris
Also going to need the casting number on the y-pipe.
achris
Ok, done a bit of research for you...
That intermediate elbow (casting #94444) was used with 15° down angle 3" exhaust elbows and a -99877A10 Y-pipe...
Never intended for a 7° 4" exhaust elbow (need the HGE number to confine what you have).
What you appear to have is a 7° 4" exhaust elbow, so you are going to need a -11086T and a -14343T intermediate elbows (one port, one stbd)... And that should be going into a -807130A4 Y-pipe (you may find casting #44266 on it. If you find #99877, that's the wrong one).
Chris.....
76SeaRay
My Y pipe is the older 3 inch round version. The existing intermediate elbows with the Y pipe are 94443 and 94444. They are too short vertically and I don't see how they attach to the new elbows/riser even though one end is about 4 inches. I bought new dry joint HGE Exhaust Manifolds (5735) and Exhaust Elbows/Risers (4309). These are interchangeable between port and starboard.
76SeaRay
I can't get at the Y pipe casting number since I have the engine set in place. I can pull it tomorrow, however, it appears I may have to get a new Y pipe based on your description. I think the -11086T and -14343T are oval on the outlet end.
achris
And that'll be the problem.
Which corresponds to the 3" Y-pipe.
HGE-4309 is a 4", 7° dry joint elbow...
Looks like you're going to need a new Y-pipe, intermediate elbows (as you said), and the interconnecting rubbers.
Exhaust elbow to intermediate elbow rubber: 32-14358001
Intermediate elbow to Y-pipe rubber: 32-44348001
Chris.........
76SeaRay
Thanks, I was afraid of that. I have seen a few of the Y pipes for sale that show multiple casting numbers for them. Some have the part number 807130 with just A (instead of A4), some have a C and others claim they work as a 807130 but have cast number 861229-C. Any idea about the compatibility?
Lou C
It almost looks as if the elbows are too long to mate with the Y pipe.
Back when I replaced the heads on my 4.3 I also had to change the exhaust since I was on my last set of OMC bat wings. I REALLY wanted to convert to the Merc dry joint system because it is a better design no doubt. But the heights, lengths and angles of each system is different enough that it can be a real headache to make it work. So I wound up going with the later 2 piece wet joint style used by both OMC & Volvo because I know it would fit judging by Y pipe casting #. And it did fit like factory no leaks either. Still would like the Merc exhaust on my engine lol!
76SeaRay
I have found two Y pipes that are listed as 807130A4. One of those has the casting number 861229-C and the other has casting number 44265C1. Will either of these work?
achris
I believe either of those will fit. Just check the shutter configuration. One may be the original design and the other the updated design. Have a look at this thread -> EXHAUST SHUTTERS EXPLAINED to see the differences. You want the updated design...
Chris...
76SeaRay
Thanks for all the info. It appears that the 44265C1 uses the old style shutters and the 861229-C uses the new style shutter.
76SeaRay
Ok, so hit a wall here and getting nowhere fast. My old 3 inch Y pipe which matches my gimbal housing is the offset bolt pattern. It appears that the 807130A4 that is needed to connect to the HGE dry joint exhaust risers is a non-offset/non-symmetrical bolt pattern. Is there a different part number for the Y pipe that fits the offset bolt pattern and the dry joint risers? Pics below of my existing gimbal housing bolt pattern, existing Y pipe bolt pattern and the 807130A4 with casting 861229C symmetrical bolt pattern. Do I have to get a new gimbal housing or get rid of my new exhaust manifolds?
nola mike
Is the issue that only 3 of the bolts will mate with the housing, or does it not fit at all?
76SeaRay
Yup, only three holes line up. I see in 90 to 92, Mercruiser added the additional top hole to the gimbal housing apparently so that either Y pipe will fit but I have the older gimbal housing with the offset. So, to put in 4 bolts, I either have to find a Y pipe with the old bolt pattern that works with my new dry exhaust/closed cooling (if it exists) or get a newer gimbal housing that has the bolt pattern for the newer Y pipe. Worried if I go for the expense of the newer gimbal housing then something else might not fit (gimbal ring or bell housing?).
nola mike
I ran into this problem as well. Scoured the web and found people that only used those 3 holes without issue, so I did the same. No leaks after 1.5 years...
achris
Doesn't exist.
Expensive, and you don't know what compatibility problems you'll be kicking down the road.
Exactly.
There shouldn't be a great deal of load on those bolts anyway, I'd do as Mike suggests, use the 3 holes that do line up. I may also consider a few things. 1) Run stainless steel thread inserts into the holes to improve strength. 2) fab up a clamping bracket that pushes on all 4 mounting points, and is held on by the three screws that do line up.
Chris.....
