exhaust hoses ???4.3 lx gen+
tashasdaddy
replacing batwings with 2 piece ready to install curved piece to exhaust Y. what should i lube rubber hoses with to help get then on riser and exhaust Y. it's like putting pvc together but it doesn't flex...
Re: exhaust hoses ???4.3 lx gen+
Dish Soap.......
boatgrunt
Are you trying to bend the rubber hose or just fit it to the riser/exhaust? If just trying to fit it, dish soap a good trick. <br /><br />If you are trying to bend the hose leaving the elbow, you shouldn't be. I made the same conversion, and my guy sold me a small angle fitting to accomplish the conversion.
Scaaty
I used wd40 with zero problems.......
tashasdaddy
thanks, thats what i thought, but to expensive to screw up, i'm using the 4" 90 from riser to exhuast Y.
