- Mar 8, 2009
- 43,237
That's a bummer, don't know if you can get it out with an easy-out, as before never tried to. Will be easier to get out with the manifolds off but the tools need to remove will be the same on or off. Being plastic should be easier to break up
Edit: just thought being plastic you can use heat, your not going to hurt the manifold with heat, need to keep plug wires clear and other things that might be effected
