exhaust manifold gaskets
tjizzle
I have a 1978 70hp evinrude was getting water in middle cylinder so i pulled head and replaced gasket. Now i wanted to replace exhuast manifold gaskets,but it seems that its alot to do this. Was wondering if ther is a way to do this without removing powerhead. Was wandering if if i could just loosen housing below powerhead enough to get to bottom bolts. Can anyone tell me if this is possible???????
Thanks TJ
boobie
Re: exhaust manifold gaskets
I've done it two ways, 1, using 1/4" drive extensions and flex sockets. 2, drilling holes in the lower cover to get at the bolts and putting rubber plugs in them when the job is done.
tjizzle
thanks boobie I appreciate the the suggestions was not looking to pull powerhead
