Fishvoodoo
- Jul 29, 2006
- 1
My 1995 Evinrude 15hp will not run at low speeds or idle. We changed plugs and did carb cleaner. When we had this problem in the past, we had it repaired and they said the exhaust path was filled with carbon. He cleaned it and suggested we run at high speeds occassionally. We also changed to a high grade oil for our fuel mix. We use the motor for trolling, but run it at high speed a while on each trip. Now its acting up again. Is there any way we can clean the exhaust paths without having to take it to the dealer? Do we need special tools to remove or disassemble lower unit to get to exhaust?
