Ez drain plug for mercruiser engine
wellcraft-classic210
Master Chief Petty Officer
Catfive
Welcome aboard !
Please consider starting your own post // It seems you may need to find & fix the water the leak source among other approaches that may save you time and $.
FYI-- ( Writing in your problems on someone else's post is call Hijacking )
dlogvine
As long as you warm the engine fully before sucking it up through the dipstick, you'll get 98% of the old oil out.
Seems to me you're looking for a way of changing the oil cold (a couple of minutes running is still cold)... Whichever way you do it, if it's cold, it's wrong.
Chris........
Thx, this might have been my problem, not warming up the oil enough. As for the drain plug, I looked in the engine compartment and determined it would be quite difficult to work with the valves drain plug
