F200TXRA Fuel Problems? LPP or LPP relay??
mokaction
Motor starts great after pumping the primer ball. Once the VST runs out of fuel the motor stalls.
Had my friend turn on the start switch and check the high pressure pump and the pump is running.
Tried the test several time with the low pressure pump and the pump is not working at all.
Removed the wiring harness and put a voltage meter negitive to the red/blue and positive on the red/yellow. Then had my friend turn on the start switch.
0 reading on the voltage meter.
Also did a bench test to the low pressure pump by adding 12 volt to the wiring harness and all it does is make a clicking sound. Is that right???
Please confirm if you think it could be the low pressure pump or the low pressure pump relay?
I know the emc is almost indistructable.
Thanks for your help in advance.
