F50 carb kits
Georgesalmon
I've got an F50TLHU I bought new, serial 62Y450764X. Can't remember the year anymore. Early 90's. Anyway I want to rebuild the carbs and looking at parts here on iboats I can't find that model. Anyone out there can help me?
Capt Ken
Re: F50 carb kits
Do you have access to the vacuum system to set them up after reinstalling?
99yam40
Re: F50 carb kits
A service manual for your motor will tell you what test equipment you need and all specs and steps for doing many things.
I beleive you would need a 4 channel vacuum mate special tool to adjust the carbs after cleaning
Capt Ken
Re: F50 carb kits
Can't work on a four stroke without one.
You will have to balance the intake vacuum or it won't idle for squat.
Also, drill out the plugs hiding the low speed air screws if they haven't already been removed
Georgesalmon
Re: F50 carb kits
just might take this to a dealer, sounds to complicated for this old guy. motor runs ok yet, just not starting as good as it used to.
