mr300z87
- Sep 15, 2010
- 697
Last weekend we met some friends out at Tices shoals a local anchor spot, in our Sea Ray Sundance 250, when we first got there I switched over to what I thought was my start battery and tried to re start the engine with out success. Switched back to both batteries and she fired up no problem. Used minimal power while out and made it home no issues. Later in the week is did some testing to find that I labeled my switch wrong and the crank condition was on the house battery. The start battery is a group 27 700 CCA marine start with a 4/2017 date and the house a group 27 600 CCA marine deep cycle dated 4/2018. With the switch on start battery only the starts engine no problem, house battery only and it won't crank the engine and volts drops to less then 7 volts when I attempted to start then back to 12 volts when stop cranking, this with a volt meter connect direct to the battery. All other accessories work on either batteryl The boat has a charger and is charging all times when in the slip. Both batteries seemed to be fully charged at time of testing. I would assume the the house battery should be able to start the engine and has failed even though it is only a year old. It is wicked hot here in NJ this weekend so I have not had a chance to go back at check the fluid level in the cells. My question is should a group 27 600 CCA deep cycle battery have enough power to start a 7.4L? Of couse I bought the battery last June and it has a1 year warranty. As always advice is always appreciated.
