ShoestringMariner
- Apr 18, 2015
- 1,605
Gee, pour the foam before you install the decking. Use a long knife to cut the foam flush to the top of the stringers. Why bother with strategically placed holes that you have to plug?
Then, lay some strips of polyester resin saturated cloth on top of the stringers and screw the new decking into the stringers with SS wood screws. Now put 1 heavy layer of cloth or 2 lighter layers of cloth over the deck and add polyester resin. Not too complicated...
as much as I think that’s the easiest method by far, cutting the foam exposes the cells to water absorption, no?
