I drained all (or most) of the antifreeze from my 470 so I could replace it with fresh 50/50 mix. I followed the procedure from the manual to fill up the coolant system, but it seems that when I fill the reservoir 1" from the filler neck, and then crank the motor, as the motor warms up, the coolant level in the reservoir rises instead of falls as the manual suggests it should do. It states that as the motor warms, keep an eye on the level and keep it to within 1" of the filler neck. But mine starts to rise and eventually overflows out of the filler neck, so I have to put on the radiator cap.
Should it be doing this? I had expected the level to drop as the air bubbles were worked out of the cooling system, and thus the coolant level would fall requiring additional coolant. I feel like it needs to take a big BURP.
Also, after idling for several minutes, the temperature was about 180 and steady, according to the dash gauge and IR thermometer. I was using the IR thermometer to check the temps on the exhaust manifold, near the radiator cap and near the reservoir drain plug on port side. Does this seem reasonable for idle?
