Filling thru holes in fiberglass hull
Robertismo
I cannot seem to find a definitive answer to the proper material for filling holes in fiberglass hull. There are a few holes that need filled from livewell pump intake ( below waterline) to screw holes and old bilge pump discharge hole (obviously above waterline). Should i simply be using PB and wax paper for all holes? I also have 5200 on hand if this feasable. Thanks in advance
are you fre-finishing the boat? or just want to fill the holes?
best way is from both sides, feather with a grinder, then a layer of CSM on both sides followed by a larger layer of 1708 on both sides. grind smooth, fair as needed, gel or paint.
if you just want to fill the holes, a patch with 5200 screwed in place
Robertismo
Yes full resto. Grinding inside of hull currently, then plan to flip and repair & paint while hull is at lightest point. So i need to repair these holes before gelling. Its a 84 starcraft v-150 modified
Woodonglass
Yup Scott has given you the correct method. Tape the outside, fill the hole with pb and smooth it then apply some CSM and 1708. On the outside 2 layers of CSM and fair and sand
